Edit custom properties dialog box
The Edit Custom Properties dialog box allows you to add custom properties to materials and compositions.
  1. In project
  2. Add Generic/ Material/Composition/Delete properties
In project
Displays the custom properties available in the project.
Add/Delete Properties
Add Generic Custom Property
Creates a new generic custom property, which can be assigned to building elements in the project.
Add Material Custom Property
Creates a new material custom property, which can be assigned to materials in the project.
Add Composition Custom Property
Creates a new composition custom property, which can be assigned to compositions in the project.
Delete
Deletes the selected property.
