Entity grouping dialog box
The Entity grouping dialog box allows you to create, modify and delete named groups of entities.
- Existing groups
- Create Group
- Change Group
Existing groups
Lists all existing groups with the Group Name and a short description.
- Display unnamed Groups
- Toggles the display of unnamed groups.
- Find Groups by entity
- Reports the name(s) of groups when entities in the drawing are selected.
- Highlight selected Groups
- Highlights all entities that belong to the selected group.
- Ungroup selected Groups
- Removes group status from selected entities.
Create Group
- Name
- Specifies the name of a group.
- Unnamed
- Toggles whether the group has a name.
- Description
- Adds an optional description of the group.
- Selectable
- Determines how groups are selected when the PICKSTYLE system variable is set to 1 or 3.
- Select entities
- Selects entities in the workspace which should be part of the group.
Change Group
- Add entities to group
Adds entities to the selected group.
- Remove entities from group
Removes entities from the selected group.
- Re-Order entities
Changes the order of entities in groups through the Order Group dialog box.
- Options in the Order Group dialog box
Group Name
Options
- Group Name: lists the names of named and unnamed groups.
- Remove from position: specifies the position number of the entity to be reordered.
- Enter new position number for the entity: specifies the new position number for the group.
- Number of entities: specifies the range of entities to reorder.
- Re-Order: applies the reordering dictated by the previous three fields.
- Highlight: highlights entities in the group; dismisses the Order Group dialog box.
- Reverse Order: reverses the order of entities in the group.
