Export DimensionStyles dialog box
The Dimension Style Export dialog box allows you to export dimension styles and their settings to an external file.
- File...
- Available Dimension Styles
- Export
File...
Opens the Select export file dialog box that allows you to choose the location for the DSE file.
Displays the available dimension styles and allows you to select the dimension styles to write to the DSE file. The selected styles are written in the file indicated under the File... button.
Export
Exports the selected dimension styles to the indicated DSE file.
