Geometric tolerance dialog box
The Geometric Tolerance dialog box allows you to place tolerance symbols in drawings.
Symbol
Specifies a tolerance symbol through the Symbol dialog box.
Tolerance 1 & 2
Specifies the tolerance specifications (diameter, value and material condition).
- Diameter
- Toggles the diameter symbol.
- Value
- Specifies the tolerance value.
- Material condition
- Specifies the material condition through the Material condition dialog box.
Datum 1, 2 & 3
Specifies the datum reference (value and material condition).
- Value
- Specifies the datum value.
- Height
- Specifies the height of the tolerance symbols.
- Datum Identifier
- Specifies datum identifier, such as Datum A.
- Projected Tolerance Zone
- Toggles the projected tolerance zone symbol.
- Tolerance Symbols
Symbol Characteristic Type Position Location Concentricity or Coaxiality Location Symmetry Location Parallelism Orientation Perpendicularity Orientation Angularity Orientation Cylindricity Form Flatness Form Circularity or Roundness Form Straightness Form Profile of a surface Profile Profile of a line Profile Circular Run-out Run-out Total Run-out Run-out
- Material Condition Symbols
Symbol Definition At maximum material condition (MMC), a feature contains the maximum amount of material stated in the limits. At least material condition (LMC), a feature contains the minimum amount of material stated in the limits. Regardless of feature size (RFS) indicates that the feature can be any size within the stated limits.
