GIS Import dialog box
The GIS Import dialog box allows you to import different GIS Features (Layers) with shapes and attributes from SHP files into the current drawing. You can also specify properties for each imported Feature.
- Current Coordinate System
- Table of imported GIS Features
- Specify Import Area
- Import
Reports the GIS coordinate system being used by the current drawing.
Lists the GIS Features to import and allows you to define their properties.
- Selected
- Allows you to select/deselect GIS features to import.
- GIS Feature
- Specifies the name of the GIS feature.
- Feature Type
- Specifies the feature type, for example lines, polygons, points, etc.
- Drawing layer
- Specifies the drawing layer on which the entities are created.
Click the Drawing layer field of the GIS feature to open the Drawing Layer dialog box to set the layer.
- Source Coordinate System
- Specifies the source coordinate system that is used in the SHP file, which is read-only.
- GIS Data
- Specifies the GIS Data.
Click the GIS Data field of the GIS feature to open the GIS Data dialog box where you can choose whether or not to import the GIS data.
- Elevations
- Specifies the elevation at which entities are created.
Click the Elevations field of the GIS feature to open the Elevations dialog box to set the elevation.
Specify Import Area
Allows you to specify the import area.
- Import All
- Uses the entire drawing as import area.
- Select clipping polygon
Click the mouse icon to select a polygon in the drawing that defines the import area.
- Draw clipping polygon
Click the mouse icon to specify an import area in the drawing.
Import
Imports the GIS features in the drawing and closes the GIS Import dialog box.
