Import sheet set dialog box
The Import Sheet Set dialog box allows you to import a sheet set file that has been created using the Export Sheet Set As dialog box.
- XML File path
- Select XML File
- Save Sheet Set As
- DST File path
- Save Sheet Set As
XML File path
Displays the path of the *.xml file after selecting it using the Select XML File button.
Select XML File
Opens the Select XML File dialog box.
Save Sheet Set As
Choose whether to save the imported XML file as DST file using:
- The same location and name as XML file. Sections named 4 and 5 are unavailable.
- Another location or name. For the second option, click the button number 5.
DST File path
When you choose to save the imported XML file as DST file to a new location or name is displayed the path of this file.
Save Sheet Set As
Opens the Save Sheet Set As dialog box.
