Load application files dialog box
The Load Application Files dialog box allows you to load and unload the following applications type to run inside BricsCAD:
  • LSP - LISP applications from BricsCAD and other CAD programs.
  • DES - DES LISP applications.
  • BRX - BricsCAD runtime extension applications.
  • TX - Teigha extension applications, from Open Design Alliance.
  • ARX - AutoCAD runtime extension applications from Autodesk.
  • DBX - DBX applications.
  • DRX - Drawing runtime extension applications.
  • DVD - Visual Basic applications.
  • MNL - LISP expressions for menu files.
  1. Add application file
  2. Load selected application
  3. Unload selected application
  4. Move application upward
  5. Move application downward
  6. Remove selected application
  7. Application Files List
  8. Application File Path
Opens the Select Application Files dialog box.
Loads the selected application(s) into BricsCAD. Only compatible applications with BricsCAD will be loaded.
Unloads the selected application(s) from BricsCAD. The LISP applications have to be removed in order to be unloaded in the current BricsCAD session.
Moves the selected application(s) up in the list.
Moves the selected application(s) down in the list.
Removes the selected application(s) from the list.
Displays a list with application files that are available for load, unload, move up and down or remove.
  • Name: specifies the name and the extension of the application file from the list.
  • Loaded: specifies if a file is loaded or unloaded in the current BricsCAD session.
  • Autoload: specifies if a file will be loaded automatically in the next BricsCAD session.
  • Path: displays the location folder of the added files.
Displays the location folder for appload.dfs file that contains all applications added, using the Select Application Files dialog box. You can open the file using Notepad.
Applications listed in appload.dfs are loaded on startup.
