Manage Routines dialog box
The Manage Routines dialog box allows you to manage the routines.
- Add routine
- Routine list
- Drop-down menu
- Edit routine
- Import routine
Add routine
Adds a new empty routine.
Routine list
Lists all the saved routines and the number of tasks for each.
Drop-down menu
By pressing the three dots, a drop-down menu opens.
- Edit
- Opens the Edit Routine dialog box to edit the routine.
- Rename
- Renames the routine.
- Duplicate
- Creates a duplicate of the routine.
- Export
- Exports the routine to a .rtn file. Opens the Export Routine dialog box.
- Delete
- Removes the routine from the list.
Edit routine
Edits the routine by pressing the right-side arrow. Opens the Edit Routine dialog box.
Import routine
Imports a routine (.rtn) file from the Import Routine dialog box.
