Navigate Settings dialog box
The Navigate Settings Dialog box allows you to adjust the navigation settings in a drawing.
- Navigation mode
- Current drawing settings
- Registry settings
Navigation mode
Toggles between Walk and Fly modes:
- Flight mode: permits movements in all three dimensions.
- Walk mode: restricts movement to the xy-plane.
Sets the settings in the current drawing, and so will be different in other drawings.
- Walk/Fly step size
- Specifies the distance the view travels with each press of the key. The distance is measured in drawing units.
- Steps per second
- Specifies how quickly the view changes when a travel key is held down.
Registry settings
Settings which are saved with the registry, they will be the same in other drawings.
- Rotation speed factor
- Specifies how quickly the view rotates.
- Keep horizon horizontal
- When toggled on, the flight level is kept. This option is grayed-out for Walk mode.
