Point Cloud Reference Manager dialog box
Enables you to attach point cloud files that have already been processed and are stored in the cache into the current drawing. It is opened with POINTCLOUDREFERENCE command.
- Process a new scan
- Attaches a point cloud file by launching the POINTCLOUDATTACH command.
- Name
- Displays the point cloud file name.
- Path
- Displays the point cloud file location.
- Size
- Displays the point cloud file size in MB.
- Status
- Displays the point cloud file status:
- Insert
- Opens the Attach Point Cloud dialog box and attaches the point cloud file in the current drawing.
- Delete
- Removes the Point cloud file from the cache.
- Cache used
- Specifies the total amount of the used cache from the total amount of available cache.
- Cache settings
- Opens the SETTINGS dialog box to set the POINTCLOUDCACHESIZE system variable value that defines the maximum allowed size of point cloud cache on disk.
