Pre-process point cloud data file(s) dialog box
The Pre-process Point Cloud Data File’s dialog box allows you to attach point cloud files (that were previously converted to BricsCAD's BPT format) to the current drawing. It is opened with POINTCLOUDATTACH command, option File.
- File Name
- Supported files
File Name
Specifies the name of the point cloud data file you want to attach.
Note: A manual search can be done in the window
above.
Supported files
Specifies the file types you will be able to choose from.
