Select Surface File dialog box
The Select Surface File dialog box allows you to select one or more point files to create a TIN surface.
  1. List of selected point files
  2. Open point file
  3. Delete point file
  4. Specify point file format
  5. Applicable formats only
  6. Manage Surface Point File Formats
  7. Preview
Displays the selected input point files to create a TIN Surface.
Open point file
Opens the Open file dialog box to select a point file. The input point file can be any ASCII file of points with any extension, any separator between columns and arbitrary arrangement of data in columns. Multiple point files could be selected.
Delete point file
Removes the point file from the list.
Selects a point file format from the opened drop-down list.
If checked, shows only formats that are applicable to all files in the list.
Manage Surface File Formats
Opens the Manage Surface File Formats dialog box.
Preview
Displays all point's coordinate according to the specified point file format.
