Sheet View Properties dialog box
The Sheet View Properties dialog box allows you to view properties of a sheet view.
  1. Number
  2. Name
  3. Description
  4. DWG Handle
  5. DST Handle
  6. Category
Number
Specifies the number of the sheet view.
Name
Specifies the name of the sheet view.
Specifies a short description of the sheet view.
DWG Handle
Displays the .dwg file handle of the named view associated with the sheet view. It is read-only.
DST Handle
Displays the .dst file handle of the sheet view. It is read-only.
Category
Specifies the category of the sheet view.
