Subset Properties dialog box
Allows to edit the subset properties.
Name: names the subset.
Description: describes the subset.
DST Handle: displays the .dst file handle of the subset. It is read-only.
New Sheet Location: sets a sheet location. (click on the three points located in the right side to open standard file dialog box to select the sheet location)
Sheet template: sets a sheet template. (click on the three points located in the right side to open standard file dialog box to select the sheet template)
Publish: toggles the publishing of the subset.
