User profile manager dialog box
The User Profile Manager dialog box allows you to set the current user profile, to
create, copy, delete, import and export profiles.
- Create
- Set Current
- Copy...
- Delete
- Export...
- Import...
- Start
Create
Allows you to create a new profile, using built-in default settings. The
Create profile dialog box displays:
- Profile name
- Allows you to type a name for the new profile.
- Description
- (Optional) Allows you to type a description for the new profile.
Set Current
Sets the selected profile as the current profile.
Note:
- You can also double click a profile to set it current.
- The current profile is marked in the list with a check mark.
Copy
Creates a new profile as a copy of an existing profile. The Copy
Delete
Deletes the selected profile.
Note: Deleting the current profile
is not possible. When trying to do so, a dialog box displays that allows to
reset all settings to factory defaults.
Export...
Exports the selected profile to an .arg (profile file) or .reg (registry file) to a
specified folder.
Note: Exporting and importing a profile
allows you to migrate user preferences from one computer to another.
Import...
Imports saved profiles.
Start
Starts a BricsCAD® session using the selected profile.
Note:
- This option is only available when the command is launched when executing profilemanager_app.exe in the BricsCAD® installation folder. By default, the path is: C:\Program Files\Bricsys\BricsCAD V22 en_US.
- If the SINGLETONMODE preference variable is set to On, it is not possible to have multiple BricsCAD® sessions open simultaneously.
