Displays the status of all digital signatures for a drawing and its Xrefs.
- Name
- Displays the drawing file name.
- Folder
- Displays the drawing folder.
- Status
- Displays if the drawing is signed with a valid digital signature or
not.
- Signed
- The drawing is signed with a valid digital signature.
- Not signed
- The drawing is not signed with any digital signature or the
modification of the drawing was saved without applying the
digital signature again.
- Unknown certificate
- The digital certificate is not located in the proper location or
the digital certificate was revoked by the certificate
authority.
- Not found
- The drawing lost its initial location.
- Invalid signature
- The signed drawing was modified in an old BricsCAD® version
that doesn't support digital signature (V21).
- Unloaded
- The referenced file is not loaded.
- Error
- An error occurred during signature validation.
- View Signature
- Opens the Digital Signature Content dialog box:
- Drawing identifying
- Displays the path of the drawing.
- Status of the signature
- Marked in green in case of a valid signature.
- Marked in red in case of an invalid signature.
- Digital Signature
- Subject: displays the certificate
name.
- Issuer: displays the author
name.
- Valid from:displays the date from
which the certificate is valid.
- Valid to: displays the date until
which certificate is valid.
- Serial number: displays the
certificate serial number.
- Comment
- Displays the signature comment.
- Signature date and time
- Displays the date and time when the drawing was signed.
- Time service
- Displays the chosen time server.
