XDATA Editor dialog box
Edits the extended entity data (xdata) associated with an entity.
- APP Name
- Value
- New value
- Pick <<
APP Name
Allows you to choose an application name from the list.
Value
Allows you to select a value from the list. Each value has a corresponding group code.
New value
Allows you to specify a new value.
Pick
Temporarily disables the XDATA Editor dialog box and allows you to pick a new value.
