Dialog boxes About BricsCAD dialog boxAdd block to library dialog boxAdd button item dialog boxAdd Entity Alias dialog boxAdd-in manager dialog boxAdd menu item dialog boxAdd plot style table dialog boxAdd quad button filter dialog boxAdd scale dialog boxAllowed deviations from center axis dialog boxAnnotation Object Scale dialog boxArray dialog boxAttach External Reference dialog boxAttach PDF underlay dialog boxAttach raster image dialog boxAttribute editor dialog boxAuto Match dialog boxBackground dialog boxBIM BCF panel - Custom login dialog boxBIM project info dialog boxBIM Properties dialog boxBIM Typed Plan Editor dialog boxBIM Typed Plans dialog boxBlade - BricsCAD LISP advanced development environment dialog boxBlock attribute manager dialog boxBlock definition dialog boxBlock Replace dialog boxBlock to Xref dialog boxBoundary dialog boxBricsys license manager dialog boxCalculator dialog boxChange dictionaries dialog boxChange Icon dialog boxChoose window style dialog boxClassify As Bim Element dialog boxColumn filter dialog boxCombine Duplicate Block Definitions dialog boxCommunicator info dialog boxCompare two models dialog boxCompositions dialog boxConfigure Settings dialog boxConfigure structure tree dialog boxConfirm deleting selected cache items dialog boxCreate detail dialog boxCreate new drawing dialog boxCreate new sheet set dialog boxCreate or edit block definition dialog boxCreate Project dialog boxCreate Schedule dialog boxCreate section/elevation dialog boxCurrent Plot Style dialog boxCustomization groups dialog boxCustomize dialog boxCustomize (Tool Palettes) dialog boxCustom properties dialog boxCustom paper sizes dialog boxDataLink edit dialog boxDatalink manager dialog boxDefault scale list dialog boxDefine attribute dialog boxDelete duplicate entities dialog boxDigital Signatures dialog boxDrawing explorer dialog boxDrawing explorer options dialog boxDrawing properties dialog boxDrawing view presets dialog boxEdit attributes dialog boxEdit custom properties dialog boxEdit hyperlink dialog boxEdit Quad Button Filter dialog boxEdit scale dialog boxEdit scale list dialog boxEntity grouping dialog boxeTransmit dialog boxExtract attributes dialog boxField dialog boxFilter Configurator dialog boxFind and replace dialog boxFlatshot dialog boxFormat dialog boxGeographic location dialog boxGeometric tolerance dialog boxHatch and gradient dialog boxHatch Edit dialog boxImport Civil 3D dialog boxImport page setups dialog boxImport sheet set dialog boxInsert block dialog boxInsert object dialog boxInsert table dialog boxLayer Property Filter dialog boxLayer settings dialog boxLayer translator dialog boxLayout manager dialog boxLinks dialog boxLoad application files dialog boxLoad linetypes dialog boxLoad Multiline Styles dialog boxLogin dialog boxManage Customizations dialog boxMap Connect dialog boxMatch Properties dialog boxMechanical Properties dialog boxMotion Path Animation dialog boxNavigate Settings dialog boxNew Layer Name dialog boxNew Multileader Style dialog boxNew Multiline Style dialog boxNew Page Setup dialog boxNew Sheet(s) dialog boxPage setup dialog boxPaste special dialog boxPhysical materials dialog boxPlot stamp dialog boxPlot style table editor dialog boxPlotter Configuration Editor dialog boxPoint Cloud Reference Manager dialog boxEnables you to attach point cloud files that have already been processed and are stored in the cache into the current drawing. It is opened with POINTCLOUDREFERENCE command.Pre-process point cloud data file(s) dialog boxPrint dialog boxProfiles dialog boxProject Database dialog boxShows the project database location. All drawings are connected to the project database.Proxy information dialog boxPublish dialog boxQLeader Settings dialog boxReassociate entity data dialog boxReference Edit dialog boxRender dialog boxRun BricsCAD VBA macro dialog boxSave block definition dialog boxSave detail dialog boxSave workspace dialog boxSecurity dialog boxSecurity options dialog boxSelect color dialog boxSelect Custom Arrow Block dialog boxSelect items to delete from cache dialog boxSettings dialog boxSet viewpoint dialog boxSheet Properties dialog boxSheet View Properties dialog boxThe Sheet View Properties dialog box allows you to view properties of a sheet view.Sheet selection sets dialog boxSheetset setup dialog boxSpatial Locations Manager dialog boxSpell checking dialog boxStandard open file dialog boxStandard save file dialog boxSubset Properties dialog boxAllows to edit the subset properties.Table Cell Format dialog boxTags dialog boxTool image dialog boxTool Properties dialog boxUpload to Bricsys 24/7 dialog boxUser coordinate system dialog boxUser profile manager dialog boxValidate Digital Signature dialog boxDisplays the status of all digital signatures for a drawing and its Xrefs. VBA manager dialog boxView Options dialog boxVisual settings dialog boxWizard page dialog boxWorking sets dialog boxWrite block to file dialog boxParent topic: BricsCAD
