Change Icon dialog box
The Change Icon dialog box allows you to change the icon of an OLE Frame entity before inserting it into the drawing. The icon is related to the document type and it is defined by the source applications.
  1. Icon
  2. Label
  3. Buttons
  4. Preview
Icon
Specifies an icon to represent an embedded or linked document.
Current
Displays the current icon.
Default
Displays the default icon.
From File
Choose another icon.
Label
Optionally edit the label text.
Buttons
The Buttons area contains OK, Cancel and the Browse button.
OK
Click OK to accept the changes and to return to the previous dialog box (Insert Object).
Cancel
Click Cancel to discard the changes and to return to the previous dialog box (Insert Object).
Browse
Displays the Browse dialog box (a standard file selection dialog box), in which you can select an icon from a file.
Preview
Displays the icon preview.
