Column filter dialog box
The Column Filter dialog box configures the column filter.
  1. Parameters
  2. Column
Parameters
Defines the parameters to use in the column filter.
Column type
Displays the name of the column you put a filter on. Selects the type of filter that should be applied to this column and configures it.
Note: The list of possible filters depends on the column content type.
Note: For all text filters, you can also specify whether they should be case-sensitive or case-insensitive.
Always accepted
All column values are accepted.
Equal to
Value should be equal to the target one.
Note: Appears with numerical columns.
Not equal to
Value should be not equal to the target one.
Less than
Value should be less than the target one.
Greater than
Value should be greater than the target one.
Less than or equal to
Value should be less than or equal to the target one.
Between
Value should be in the given range, both ends excluded.
Not in range
Value should not be in the given range, both ends excluded.
Exactly matches
The content of the column should exactly match the target one.
Note: Appears with columns containing text.
Does not match
The content of the column should be different from the target one.
Starts with
The content of the column should start with the given text.
Does not start with
The content of the column should not start with the given text.
Ends with
The content of the column should end with the given text.
Does not end with
The content of the column should not end with the given text.
Contains
The content of the column should contain the given text.
Does not contain
The content of the column should not contain the given text.
Matches pattern
The content of the column should match the given wildcard template.
Does not match pattern
The content of the column should not match the given wildcard template.
Included in
The content of the column should be in the given set of values.
Note: Appears with columns containing text and numerical columns.
Not included in
The content of the column should not be in the given set of values.
