Customize (Tool Palettes) dialog box
The Customize (Tool Palettes) dialog box allows you to customize your own tabs and tools to use in the tool palettes panel.
- Palettes
- Palette Groups
Palettes
Displays a list of all palettes available in the tool palettes panel. By right clicking on one of the palettes, several options may be available in the context menu.
- Rename
- Renames the Palette by entering the new name.
- New Palette
- Adds a new Palette to the list with a generic name that can be changed right away.
- Delete
- Deletes the selected palette
- Export
- Exports a palette through the Export Palette dialog box.
- Import
- Imports a palette through the Import Palette dialog box.
Palette Groups
Displays the loaded palette groups. By right clicking on one of the groups, several options may be available in the context menu.
- New group
Adds a new sub-group to the list with a generic name that can be changed right away.
Note: For the additional sub group, the available options in the context menu are the same as those for palettes.
- Import
- Imports a palette through the Import Palette Group dialog box.
