Custom paper sizes dialog box
The Custom Paper Sizes Dialog Box allows you to create custom paper sizes when Print as PDF.pc3 is selected in the Printer/Plotter Configuration list.
  1. Custom Paper Sizes list
  2. Name
  3. Paper Size
  4. Paper Margins
  5. Add
  6. Delete
  7. Units
Displays the list of all custom paper sizes created by the user.
Name
Allows you to name the custom paper size.
Paper Size
You can insert the width and the height of the page in the appropriate fields.
Paper Margins
You can set the paper margins by entering the desired values in the fields. Only positive values are allowed.
Add
Allows you to create the new custom paper size and adds it to the list.
Delete
Allows you to select a custom paper size from the list and delete it. You can delete one item at a time.
Units
You can choose whether to use inches or millimeters for your custom paper size.
