Filter Configurator dialog box
The Filter Configurator dialog box allows you to specify the conditions to filter components in the BOM table.
  1. Columns
  2. Properties
  3. Add
  4. Delete
  5. Expression
  6. Conditions
  7. Expression Editor
Columns
Selects columns to apply the filter to.
Properties
Specifies the available properties that can be used to apply the filter.
Note: When specified the options above, the condition can be added by pressing the plus sign.
Filter conditions
Displays the conditions were added. This includes the properties, it’s condition, value and unit.
Add
Adds a condition for the selected property.
Delete
Deletes the selected condition(s) from the filter.
Expression
Shows or hides the expression editor.
Conditions
Displays all the added conditions that will be used to filter the content of the BOM table.
Expression Editor
Displays the Expression Editor where you can configure and preview the filtering expression.
