New Sheet(s) dialog box
The New sheets dialog box allows you to create (a) new sheet(s) within an existing sheet set.
When starting from scratch, the dialog box includes 5 areas. By selecting the Import layouts from existing drawings option, the dialog box includes 4 areas.
  1. Number
  2. Title
  3. File name
  4. Folder path
  5. Template
  1. Add drawing(s)…
  2. Sheet titles
  3. Automatic numbering
  4. Leading zeroes
Create from scratch
Allows you to create a new sheet from scratch
  • Number: defines the number of sheets.
  • Title: defines the title of the new sheet(s).
  • File name: defines the name of the file in which the new sheet(s) will be saved.
  • Folder path: defines the location of the file.
  • Template: choose the template of the new sheet(s).
Import layout
Allows you to create a new sheet with properties of an existing layout
  • Add drawing(s)…: selects drawings to import a layout from through the Select Drawing(s) dialog box.
  • Sheet titles: specifies how the selected drawing should be listed by selecting one of the options in the drop-down list.
    • Drawing name: displays the drawing name of the selected drawings.
    • Drawing name- Layout name: displays the drawing name and the layout name of the selected drawings.
    • Layout name: displays the layout name of the selected drawings.
  • Automatic numbering: numbers the layouts automatically.
  • Leading zeroes: specifies how the Number value of new sheets is formatted by adding zeroes at the start of a sheet number.
