Sheet Properties dialog box
The Sheet Properties dialog box allows you to view and edit properties of a sheet.
- Number
- Name
- Description
- DWG Handle
- DST Handle
- Destination File
- Publish
- Category
- Library Status
- Custom Sheet properties
Number
Specifies the number of the sheet.
Name
Specifies the name of the sheet.
Specifies a short description of the sheet.
DWG Handle
Displays the .dwg file handle of the layout associated with the sheet. It is read-only.
DST Handle
Displays the .dst file handle of the sheet. It is read-only.
Destination File
Specifies the .dwg file in which the sheet will be saved.
Publish
Toggles the option to publish the sheet.
Category
Specifies the category of the sheet.
Library Status
Specifies the library status.
Custom Sheet Properties
Lists and allows to edit the custom sheet properties, if any exists.
