Tool Properties dialog box
- Image
- Name
- Description
- Command String
- General
Displays an image of the selected tool.
Name
Specifies the name of the selected tool.
Specifies the description of the selected tool.
Command String
Specifies the macro to run when you click the icon; you can use any macro characters used for menus and toolbar buttons.
General
Specifies the properties of the entity; the properties vary, depending on the tool.
