BricsCAD Communicator - Supported export file formats
Supported export file formats:
Windows
- 3D PDF: .pdf
- ACIS: .asab, .asat, .sab, .sat
- CATIA v4: .model
- CATIA v5: .CATPart, .CATProduct
- IGES: .iges, .igs
- STEP: .step, .stp
The following export protocols can be specified; AP203, AP214, AP242
- VDA-FS:.vda
- XCGM: .xcgm
Linux
- 3D PDF: .pdf
- CATIA v4: .model
- CATIA V5: CATProduct, .CATPart
- IGES: .iges, .igs
- STEP: .step, .stp
- VDA-FS:.vda
- XCGM: .xcgm
Mac
- CATIA v4: .model
- IGES: .iges, .igs
- STEP: .step, .stp
- VDA-FS:.vda
Note: When the EXPORTPRODUCTSTRUCTURE system variable is set, you
can export a BricsCAD® assembly with
mechanical components as a file with product structure.
Note: If the assembly contains hidden parts, you can decide how to
process the export hidden parts by setting the EXPORTHIDDENPARTS system
variable.
Note: All other related system variables which controls the export
file types are listed in the Related variables.
