Compatibility between Communicator and BricsCAD
BricsCAD Communicator® works with a BricsCAD® Pro license or higher.
About
The two first product numbers must match. For example, BricsCAD 22.1.xx is only compatible with BricsCAD Communicator 22.1.xx. Previous BricsCAD® versions (V21 or older) are not compatible.
There's one exception: For BricsCAD Communicator® V21, all BricsCAD® versions are compatible, provided that the major version number is 21.
Note:
- BricsCAD Communicator® V22 installs and runs independently of previous versions.
- The compatibility between BricsCAD Communicator® and BricsCAD® is always mentioned in Release Notes for BricsCAD Communicator®, under Versioning. The Release Notes for BricsCAD Communicator® are available from the download page.
We strongly recommend using the latest product version of the major version number.
