Creating regions
The REGION command converts closed entities Into a solid entity.
You can create regions from closed entities, such as polylines, polygons, circles, ellipses, closed splines and donuts.
Creating regions typically has no visible effect on a drawing using a wireframe visual style. However, if the original entity had a width or lineweight, that information is lost when you create the region.
In rendered visuals styles, region entities are displayed using a solid fill.
To create regions
  1. Launch the REGION command.
    You are prompted: Select entities or boundaries [selection options (?)]:
  2. Select one or more entities.
    Entities in set: x
  3. Select more entities or press Enter to stop selection.
  4. BricsCAD reports: x region(s) created.
