Drawing circles
The default method for drawing a circle is to specify a center point and a radius.
Other methods to draw circles can be found in the Circle submenu of the Draw menu and in the Circles toolbar.
The AI_CIRCTAN command draws circles tangent to three linear entities.
The Circle tool is available on:
  • The Draw menu.
  • The Draw toolbar.
  • The Draw ribbon panel.
  • The Draw tab of the No Selection Quad.
General procedure
  1. Launch the CIRCLE command.
    Prompts you:
    Select center of circle or [2 Point/3 Point/Tangent-Tangent-Radius/turn Arc into circle/Multiple circles]:
  2. Specify a point.
    Prompts you: Set Radius or [Diameter]:
  3. Do one of the following:
    • Press Enter to accept the current radius.
    • Type a new radius and press Enter.
    • Click to define the radius graphically.
Drawing a circle tangent to three entities
  1. Launch the AI_CIRCTAN command.
    Prompts you: Enter Tangent spec:
  2. Click a linear entity.
    Lines, arcs, circles, polyline segments, xlines and rays are accepted.
    Prompts you: Enter second Tangent spec:
  3. Click the second linear entity.
    Prompts you: Enter third Tangent spec:
  4. Click the third linear entity.
    A circle tangent to the three selected entities is created.
Editing a circle
  1. Select the circle.
    The properties of the circle display in the Properties panel.
  2. Type a new value in the Center, Radius, Diameter, Circumference or Area field, then press Enter.
  3. Press the Esc key to stop editing the circle.
