Annotative leaders
Multileaders are created using the current Multileader style:
  • If the Multileader style is annotative, the Multileader entity gets the annotative property automatically and the current annotation scale is assigned.
  • If the Multileader style is not annotative, you need to make the Multileader entity annotative manually.
To make a Multileader entity annotative
  1. Select the Multileader entity.
    The properties of the selected Multileader entity are displayed in the Properties panel.
  2. Select the Annotative property.
  3. Choose Yes in the options list.
    The current annotation scale is assigned.
    The Multileader entity is scaled with respect to the current annotation scale.
To remove the annotative property
  3. Choose No from the options list.
