Creating diametrical and radial dimensions
The DIMCENTER and DIMDIAMETER commands create diametrical and radial dimensions to annotate the radii and diameters of circles and circular arcs.
To create a diametrical dimension
  1. Launch the DIMDIAMETER command.
    You are prompted: Select arc or circle to dimension [selection options (?)]:
  2. Select an arc or a circle.
    The diametrical dimension is dynamically displayed.
  3. Specify a point to position the dimension entity.
To create a radial dimension
  1. Launch the DIMRADIUS command.
    The radial dimension is dynamically displayed.
