Editing block attributes
Block attributes can be edited in the Properties panel.
  1. Select a block containing attributes.
    The current value of the attributes is displayed in the Properties panel.
  2. Select the attribute you want to edit.
    The settings field of the selected attribute is active.
  3. Type a new value, then press enter or select another attribute.
