BricsCAD user files
In BricsCAD user files are stored in specific folders:
  • PlotConfig: plotter configuration files (*.pc3)
  • PlotStyles: plot style table files (*.stb) and plot color table files (*.ctb)
  • 支持:
    • hatch pattern files (*.pat)
    • line style files (*.lin)
    • alias files (*.pgp)
    • unit files (*.unt)
    • custom user interface files (*.cui)
    • BIM library files (*.bsyslib) see BIMPROJECTINFO command.
    • Structure tree configuration files (*.cst) see STRUCTUREPANEL command.
    • Library panel configuration files (*.ccf) see LIBRARYPANELOPEN command.
  • Templates: template drawings (*.dwt)
操作系统 文件夹 Subfolders
Windows C:\Users\<UserName>\AppData\Local \Bricsys\BricsCAD\<Version>\en_US \Templates
Windows C:\Users\<UserName>\AppData\Roaming \Bricsys\BricsCAD\<Version>\en_US
\PlotConfig
\出图样式
\支持
Mac /Users/<UserName>/Library/Preferences/Bricsys/BricsCAD/<Version>/en_US
/PlotConfig
/出图样式
/支持
/样板
Linux /home/<UserName>/Bricsys/BricsCAD/<Version>/en_US
/PlotConfig
/出图样式
/支持
/样板
The BricsCAD user file manager
When you update, the first time you launch BricsCAD after the update, the content of the UserDataCache subfolder of the BricsCAD installation folder is compared with the content of the user file folders. If you have customized files in these folders and if one or more of the corresponding files in the UserDataCache folder are more recent, the BricsCAD user file manager dialog box appears, asking you whether to keep or to overwrite your files with the new version.
Do one of the following:
  1. Select a file in the file list, then click the Yes button to overwrite or click the No button to keep your file.
    • Repeat this procedure for each file in the list.
    • Click the Yes to all button to replace all your files with the more recent files from BricsCAD.
    • Click the Stop Copying button to keep all your files.
  2. If you have decided not to update one or more files, an alert window appears, listing all files that you want to keep and that therefore will not be updated. You are asked whether or not to be reminded the next time you start BricsCAD.
  3. Do one of the following:
    • Click the Yes button if you want to update one of these files later.
      In this case this procedure is restarted the next time you start BricsCAD.
    • Click the No button if you do not want to be reminded.
