Creating a partial CUI file
  1. Launch the CUSTOMIZE command.
  2. Do one of the following:
    • In the File menu, choose Create new partial CUI file ...
    • Place the cursor on a Menu group, then right-click and choose Create new partial CUI file ... in the context menu.
    The Create a Customization File dialog opens.
    By default the new partial CUI file will be created in the Support folder.
  3. (Option) Select a different folder to save the CUI file in.
  4. Type a name for the new CUI file in the File name field.
  5. Click the Save button.
    The newly created Partial CUI file is loaded and a Menu Group of the same name is created in the Menus, Toolbars, Ribbon, Keyboards, Mouse, Tablet and Quad tab and in the Available Tools pane of the different tabs.
