Creating keyboard shortcuts
- In the Customize dialog box, click the Keyboard tab.
- Do one of the following:
- Select a menu group, then right-click and choose Append
shortcut in the context menu.
The new shortcut will be added below the last shortcut.
- Select an existing shortcut in a menu group, then right-click and choose
Insert shortcut in the context menu.
The new shortcut will be added above the selected shortcut.
The Add keyboard shortcut dialog box appears.
- Select Add an existing tool, then select an existing tool.
- Select Add a new tool, then create a new tool.
See the Create a tool in a toolbox procedure in Managing Toolboxes.
- In the Properties grid of the new shortcut, select the Key field, then press the key combination you want to assign to the shortcut.
