Creating menus
Main menus sit in the menu bar at the top of the BricsCAD application window. Submenus show as a flyout of a main menu.
The MENUBAR system variable controls the display of menus.
Creating a main menu
  1. In the Customize dialog, click the Menus tab.
  2. Do one of the following:
    • Click the Main Menus subgroup of a menu group, then right-click and choose Append main menu in the context menu.
      The new menu will be added below the last existing menu.
    • Select an existing menu in the Main Menus subgroup, then right-click and choose Insert main menu in the context menu.
      The new menu will be added above the selected menu.
    The Add Main Menu dialog box appears.
  3. Type a name in the Title.
  4. Click the OK button.
    The main menu is created.
  5. Add items to the menu.
Note: The new main menu is not visible in the menu bar until at least one menu item is added to it.
Adding a submenu to a main menu
    If collapsed, expand the menu group.
    If collapsed, expand the Main menus group of the menu group.
    • Select a main menu, then right-click and choose Append submenu in the context menu.
      The new submenu will be added below the last existing submenu.
    • Select an existing submenu, then right-click and choose Insert submenu in the context menu.
      The new submenu will be added above the selected submenu.
    The Add submenu dialog box appears.
  3. Type a name in the Title field.
    The submenu is created.
  5. Add items to the submenu.
Adding a submenu to a submenu
  2. Expand the submenu.
  3. Select an item in the submenu, then right-click and choose Insert submenu in the context menu.
  4. Type a name in the Title field.
  5. Click the OK button.
  6. Add items to the submenu.
