When you start migrating to BricsCAD, you’ll find that there are
virtually no differences in BricsCAD LISP versus OtherLISP. Your
code loads and runs, and the functionality is identical. The primary
differences when “porting” your apps will be a few minor setup
steps, Command line structure, and possibly file locations. To
start, let's review the setup and launch of your existing programs
in BricsCAD.
If you are auto-launching your programs using Acad.lsp or
Acaddoc.lsp, you will need to rename them as
on_start.lsp or on_doc_load.lsp respectively. The
best solution is to use on_doc_load.lsp, rather than
on_start.lsp.
BricsCAD Settings Panel
To enable auto-launching your program set the ACADLSPASDOC system
variable to 1 or simply toggle the option in Settings / Program options
/ System:
It is also recommended that you spend a little time familiarizing
yourself with the Options/Setting menu in BricsCAD, as there are
settings and options specific to BricsCAD environment.
The next step in the settings dialog would be to add your support
folders to the Files search path, which is found within Settings /
Program Options / Files:
It is recommended to use the support paths added as in the manner above
and/or located one level below the current project folder. It is a good
practice to use a findfile function to validate the file exists
before proceeding with your commands, as in the method below:
This is one of the methods you can use to demand-load your functions
within the on_doc_load.lsp file:
This is one of the methods you may use to demand-load your functions
within the on_start.lsp file:
The DEFUN command (DEfine FUNction) is the same name as the function
inside your on_doc_load.lsp file and that function redefines the
calling function when it’s launched.
Drawing Setup Lisp Routines for BricsCAD
Code sample
The below simple drawing setup routine could be adapted to your needs
with minimal changes.
(defun C:MYSETUP ( / ) ;define the command line function "mysetup"
(setvar "cmdecho" 0)
(command "_audit" "_y") ;audit current drawing
(command "_-purge" "_all" "*" "_n") ;purge all unused styles, etc
(command "_-layer" "_m" "1" "_c" "1" "" "") ; create layer "1" color "1"
(command "_-layer" "_m" "2" "_c" "2" "" "")
(command "_-layer" "_m" "3" "_c" "3" "" "")
(command "_-layer" "_m" "4" "_c" "4" "" "")
(command "_viewres" "_y" "20000") ;set view resolution to maximum
(setvar "filedia" 1) ;turn file dialogs on
(setvar "attdia" 1) ;turn attribute dialogs on
(setvar "attreq" 1) ;enable attribute editing on placement
(setvar "cecolor" "bylayer") ;set current color bylayer
(setvar "clayer" "0") ;set current layer to "0"
(setvar "maxsort" 5000) ;set maximum layer sort to 5,000
(command "_zoom" "_e" "_zoom" "0.95x") ;zoom extents, then out a little
(setvar "cmdecho" 1)
(princ)
Each individual line in this drawing setup routine could have been typed
in at the command line in BricsCAD®. By wrapping
them into a Lisp routine, the defun (define function)
makes the drawing setup routine "callable" from a menu or by typing its
name on the BricsCAD®
Command line.
If you don’t include defun, the program will run
once, when you load it by its file name. Using defun and
loading this routine within your lsp, will make the function
available at any time by typing its function name:
mysetup.
The commands with preceding dashes (e.g.
-layer and -purge) are used to prevent the
command’s dialog boxes from launching.
Note: Always use English command and options
names to avoid fails on localized (non-English) BricsCAD
versions.
A good practice when opening files from others is to execute an
audit followed by a purge to remove any unused
items.
Purge command could be run multiple times to
remove nested items. See the below example:
(repeat 3 (command "-purge" "all" "*" "n"))
Note:Purge is done before adding the
new, empty layers, as they would be removed if we did it
after.
The command calls for setting layers could be combined into a
single command statement, but it’s easier to read when each line
stands alone.
The setvar calls for setting a system variable to a specified
value, e.g. style settings for dimensions and text, unit settings,
etc.
The maxsort setting was introduced for two reasons.
Maxsort controls the maximum number of dialog box entries
that will be sorted.
The default value for maxsort is 1,000. With today’s
computers and often found larger project files, that number can
be too low.
If you open drawings where the layer names won’t sort into
alphabetical order, the default maxsort value could be the
reason.
A more versatile Layer Maker for your drawing setup routine
The following example could be added to your version of mysetup.lsp. By
creating a simple text file “Layers.txt” with an editor like Notepad,
you can add a list of layer names to be created when the routine is run.
This is an alternative to the hard-coded process shown above. By using
the findfile function, BricsCAD will first search the current directory,
then sequentially through your defined support folders to find the
Layers.txt file. You can place your default layer setup text file in the
support path and place alternative versions of it in individual project
folders.
(if (not (findfile "Layers.txt")) ;"not" = looking for no result from findfile
(alert "Can't find Layers.txt!") ;No file? Yell at the user and exit!
(progn ;Otherwise, do the stuff in the progn group
(setq layerfile (open (findfile "Layers.txt") "r")) ;open layers.txt to "read"
(while (setq layername (read-line layerfile)) ;while reading each line, store the text to layername
(command "-layer" "m" layername "") ;make layer with the layername
) ;end the while loop
(close layerfile) ;close the Layers.txt file
) ;end the progn
) ;end the if
