Nudge
The Nudge drawing aid allows you to move selected entities or subentities in small increments along the X, Y, or Z axis using the keyboard.
Using Nudge
- Select one or more entities or subentities (for example polyline segments or 3D solid faces).
- Do the following to move the selection:
Along the X axis of the current coordinate system:
Hold down the Ctrl key, then use the left/right arrow keys.
The Command line reads: NUDGE: offset along the X axis of the UCS: xx*
Along the Y axis of the current coordinate system:
Hold down the Ctrl key, then use the up/down arrow keys.
The Command line reads: NUDGE: offset along the Y axis of the UCS: xx*
Along the Z-axis of the current coordinate system:
Hold down the Shift key, then use the up/down arrow keys.
The Command line reads: NUDGE: offset along the Z axis of the UCS: xx*
* The step size used by the NUDGE functionality is based on the adaptive grid snap resolution. Zoom in/out to decrease/increase the step size.
