Express tools
The Express Tools are integrated in BricsCAD to improve your drawing productivity. They contain a wide range of functions that allow modifications to layers, blocks, text, dimensions and much more to improve your efficiency.
You can access most Express Tools accessed from the ExpressTools tab on the Ribbon.
You can also access the Express Tools using the corresponding commands.
