Choosing the workspace
Default workspaces are:
- Drafting: uses the ribbon.
- Drafting (toolbars): uses menus and toolbars.
- Modeling: requires a BricsCAD® Pro or higher license level; uses the ribbon.
- Modeling (toolbars): requires a BricsCAD® Pro or higher license level; uses menus and toolbars.
- Mechanical: requires a BricsCAD® Mechanical or BricsCAD® Ultimate license level.
- BIM: requires a BricsCAD® BIM or BricsCAD® Ultimate license level.
The current workspace configures the overall layout of the BricsCAD® application window.
A workspace defines the content of:
- Menus
- Toolbars
- Panels
- The ribbon
- The Quad basics
You can set the current workspace in:
- The BricsCAD Launcher.
- The Current Workspace field in the Status bar.
- The Workspaces toolbar.
- The WORKSPACE command.
