Creating a drawing
There are several ways to create new drawings in BricsCAD:
- In the Start tab.
- Using the QNEW command.
- Using the NEW command.
- Using the NEWWIZ command.
- Double clicking a *.dwt file in a Windows Explorer window.
Note: A new drawing is always created as a copy of a template drawing. The default
template is saved through the BASEFILE system variable.
