Entity creation settings
New entities are created on the current layer, using the current entity creation settings.
You can define entity creation settings in the General section of the Properties panel.
By default, all entity creation settings are set ByLayer. This means that the corresponding setting of the current layer is used.
Layer properties can be set in the Layer section in the Drawing Explorer dialog box.
