Look From widget
The Look From widget allows you to control the display of your drawing. You can select a number of preset views, such as orthographic views and isometric views.
By default, the Look From widget displays in the top right corner of the graphic screen.
The behavior of the Look From widget can be controlled by a number of system variables and user preferences.
