Prompt menus
When executing a command, BricsCAD prompts you in the Command line or the Status bar. Optionally, command options are also available in a prompt menu.
Whether prompt menus are displayed and where they are located is controlled through theāÆPROMPTMENU system variable.
The PROMPTMENUFLAGS system variable controls the content and behavior of prompt menus.
