License options
License options include academic, single-user, network, and volume licensing.
Academic license
Single-user license
The single-user license agreement is for a single user. Each single-user license allows 2 activations. You can install it on 2 machines, for example on a workstation in the office and on a laptop in the field. However, only 1 license can be in use at once. Single-user-licensing is available for perpetual or rental licensing.
Network license
The network licensing agreement enables multiple users to access BricsCAD within a LAN (Local Area Network). The number of available network licenses defines the number of users who can concurrently use the software. The network license option is available for perpetual or rental licensing and includes a 1-year maintenance contract.
Volume license
The volume licensing agreement allows you to use BricsCAD within a defined user base. You can install the software using a single license key valid for every user. The volume license option is available for perpetual or rental licensing and includes a 1-year maintenance contract.
