Reactivate BricsCAD after installing a
new hard disk, changing partitions, or upgrading the operating system.
To deactivate a BricsCAD license, an
internet connection is required. You cannot manually deactivate a license via another
computer that is connected to the internet.
You cannot deactivate:
Single and volume licenses that are manually activated.
Network licenses.
Trial licenses.
The chart explains how to deactivate a BricsCAD license. If it is not possible to
deactivate a BricsCAD license, you can
revoke the license.
Deactivating a license
Launch the LICENSEMANAGER command. Click the Manage
License option on the Bricsys License
Manager dialog box.
The Licensing Information dialog box
displays.
If your computer connects to the license server through a proxy server, click
Proxy Settings... to configure the proxy settings.
Click Deactivate...
Click the Yes button on the confirmation dialog box to deactivate the license.
The license is deactivated and can be activated on another computer.
Revoking a license
Only revoke a license if deactivation is not possible.
Use this procedure to:
Deactivate a network license or a single or volume license manually that is manually activated.
Reactivate BricsCAD after a hard
disk crash.
installing a new hard disk, changing partitions, or upgrading the operating
system.
Migrate a license to another computer.
Permanently remove BricsCAD from
a computer.
Log in to the Bricsys website.
Make sure you log in with the Bricsys account containing your licenses.
Click the My Account icon () and select
Manage Licenses in the menu.
Hover over the license key of the license you want to revoke and click on the
pencil icon ().
Scroll down and click the X icon to revoke the license.
Deactivating or revoking a BricsCAD license - BricsCAD | Bricsys Help Center
