Deactivating or revoking a BricsCAD license
- Migrate a license to another computer.
- Permanently remove BricsCAD® from a computer.
- Reactivate BricsCAD® after installing a new hard disk, changing partitions, or upgrading the operating system.
To deactivate a BricsCAD® license, an internet connection is required. You cannot manually deactivate a license via another computer that is connected to the internet.
You cannot deactivate:
- Single and volume licenses that are manually activated.
- Network licenses.
- Trial licenses.
The chart explains how to deactivate a BricsCAD® license. If it is not possible to
deactivate a BricsCAD® license, you can
revoke the license.
Deactivating a license
Revoking a license
Use this procedure to:
- Deactivate a network license or a single or volume license manually that is manually activated.
- Reactivate BricsCAD® after a hard disk crash.
