BricsCAD and AutoCAD® feature comparison
BricsCAD versus AutoCAD® feature comparison.
Drawings
BricsCAD AutoCAD®
Lite Pro BIM Mechanical Ultimate LT Full
Native DWG file format (thru AutoCAD 2021)
Password Protection - -
eTransmit
Sheet Set Manager
Geographic Location
Drawing Compare
Cloud Collaboration
Interface
BricsCAD AutoCAD®
Dark and Light Color Themes
Industry standard commands, aliases, and variables
Command Line (Autocomplete, Midstring,
Clickable options)
Start tab
File (Drawing) tabs
Model and Layout tabs
Layout Manager - -
Menu bar
Toolbars
Ribbon
Tool Palettes
Contextual Right-click Menus
Contextual Quad Menu - -
Status Bar
Workspaces
Searchable Settings (Variables) Dialog Box - -
Lockable Interface
Clean Screen Mode
Drawing Explorer - -
Customizable User Interface (CUI)
Structure Browser - -
Selection, snap & track
BricsCAD AutoCAD®
Selection Filtering (QSELECT)
Add Selected
Select Similar
Selection Cycling
Entity Snaps (Osnaps)
Polar Tracking
Zintersection 3D snap - -
Nearest Distance - -
Adaptive Gridsnap - -
Real-time boundary detection - -
2D Dynamic UCS - -
3D Dynamic UCS -
Drawing tools
BricsCAD AutoCAD®
Line, Polyline, 3D Polyline, Spline, Ray, Xline
Multiline and Multiline Styles -
Circle, Arc, Ellipse, Elliptical Arc
Polygon, Rectangle, Region, Donut, Point
Helix -
2D Parameters, Constraints -
2D Autoconstrain 1 1
Annotation tools
BricsCAD AutoCAD®
Dimensions, Dimension Styles
Multi-leaders, Multi-leader Styles
Single and Multi-line text, Text Styles, Text Editor
Hatches, Gradients, Hatch/Gradient Editor
Wipeouts
Revision Clouds
Attributes, Attribute Editor
Tables, Table Styles
Fields
Data Extraction -
Data Linking
Annotation Scaling
Spell Check
AutoCAD Mechanical Compatibility: Read, Display, Edit (with limitations) - - - - -
Editing tools
BricsCAD AutoCAD®
Move, Copy, Rotate, Scale, Stretch, Mirror, Align
Trim, Extend, Lengthen, Break, Join
Fillet, Chamfer
CopyGuided - -
MoveGuided - -
Grip Edit
Properties panel
Manipulator (3D Gizmo) -
Draworder
Undo Per Entity (Property History) - -
Optimize - -
Simplify - -
Reference tools
BricsCAD AutoCAD®
Blocks, Block Editor
Dynamic Blocks 2 2 2 2 2
Block Face Camera - -
Blockify - -
Associative Arrays
Dwg (Xref) Attach, Clip, Bind, Edit
PDF Attach, Clip
Image Attach, Clip, Adjust, Transparency
Point Clouds Colormap - -
Visualization tools
BricsCAD AutoCAD®
Layers, Layer States
Transparency
Visual Styles -
LookFrom (ViewCube™) -
Match Perspective - -
Lights - -
Sun Properties - -
Materials - -
Render - -
Animation Editor - - -
Walkthrough navigation - -
ANIPATH command - -
Modeling tools
BricsCAD AutoCAD®
ACIS Modeling - -
Solid and Surface Modeling - -
Solid Primitives - -
Mesh Primitives - -
Polysolid - -
Union, Subtract, Intersect, Interfere - -
Extrude, Revolve, Loft, Sweep, Thicken - -
Twist - - -
Fillet, Chamfer - -
Slice - -
Multi-slice - - -
T Connect, L Connect, Connect with Nearest - - -
Extract Edges - -
Direct modeling - -
Deformable (Freeform) Modeling - -
Audit, Simplify -
Stitch - -
3D Parameters, Constraints - -
3D Autoparametrize - - -
3D Blockify and ParametricBlockify - - -
3D Parametric Design Tables - - -
Section planes - -
Drawing Views: Base, Projected, Section, Detail and Break Views - -
3D Threads - - -
Point Cloud Align - - -
Point Cloud Bubble Viewer - -
Civil tools
BricsCAD AutoCAD®
TIN Surface Modeling - - -
Civil Points - - -
TIN Volume Surface - - -
Grading - - -
Alignments - - -
Profiles (Vertical Alignments) - - -
Corridors - - -
Civil 3D Object Enabler -
Boundary Trim - - -
Building tools
BricsCAD AutoCAD®
CAD-based BIM features - - - - -
Structural Modeling Toolset - - - - -
Project Database - - - - -
Library Database - - - - -
Site, Building and Stories - - - - -
Windows and Doors - - - - -
Fully Parametric BIM Component Creation - - - - -
3D Spaces - - - -
Quickdraw - - - - -
Quickbuilding - - - - -
Point Cloud Floor Detection - - - - -
Point Cloud Projection - - - - -
Point Cloud Geometry Detection - - - - -
Point Cloud FitPlanar (geometry detection) - - - - -
Propagate - - - - -
Custom BIM Properties - - - - -
Drawing Customizations - - - - -
Analytical Model - - - - -
Python Scripts (Beta) - - - - -
Manufacturing tools
BricsCAD AutoCAD®
Mechanical Browser - - -
Parts Library - -
Piping - - -
Assembly Modeling - - - - -
Exploded Views - - - - -
Kinematic Analysis - - - - -
Bill of Materials - - - - -
Balloons associated with BOM and Drawing Views - - - - -
Sheet Metal Design - - - - -
3D Solids to Sheet Metal Parts Recognition and Conversion - - - - -
Corner Relief for Adjacent Edge Flanges - - - - -
Lofted Bends - - - - -
Other features: Junctions, Miters, Tabs, Form Features - - - - -
Coloring - - - - -
Diagnostic & Repair for Invalid Sheet Metal Features - - - - -
Batch Processing - - - - -
Import, export, output
BricsCAD AutoCAD®
Print/Plot
Publish/Batch Plot
CTB & STB Table Files
PC3 Printer Configuration Files
Named Page Setups
PDF Import, Export
DAE Import, Export - -
IFC Import, Export - - - -
3DM Import, Export - - -
LandXML Import, Export - - -
Import Civil 3D - - -
RFA Import - - - - -
SKP Import - - -
DGN Import
RVT Import - - - - -
DWF Export
SVG Export - -
FBX Export - -
STL Export -
Point Cloud Export (see below the available formats) - - 3
las - - 3
pts - - 3
Point Cloud Import (see below the available formats) - - 3
las - - 3
laz - - 3
pts - - 3
ptx - - 3
e57 - - 3
rcs - -
rcp - -
Additional formats available with BricsCAD Communicator (see below)
CATIA V4 4.1.9 − 4.2.4 - -
CATIA V5 V5R8 − V5−6 R2021 - -
IGES up to 5.3 - -
Inventor V11 − V2022 - -
JT 8.x, 9.x, 10, 10.2, JT 10.3, and JT 10.5 - -
NX 1 − NX 195311 − NX 1953 - -
Parasolid 9.0.x − 33.0.x - -
Pro/E / Creo 16 − Creo 8.0 - -
Solid Edge V18 − SE 2021 - - -
SolidWorks 2003 − 2021 - -
STEP AP203, AP214, AP242 - -
STL All (Graphical data only) - - -
VDA−FS 1.0 − 2.0 - - -
XCGM R2012 − 2021 1.0 - - -
Programming
BricsCAD AutoCAD®
ActiveX -
Extended Entity Data Editor -
Script Recorder -
Full LISP Support (vl, vlr, vla and vlax) -
Solutions Development System (SDS/ADS) -
DCL engine -
COM API - -
VBA Projects Support - -
.NET - -
BRX (ARX) - -
TX (Teigha eXtensions) - -
CUI menu files support, with Diesel expressions
Licensing
BricsCAD AutoCAD®
Multi-platform Licenses - -
Perpetual - -
Perpetual + Maintenance - -
Subscription
Network Multi-user - -
Volume (Perpetual) - -
Academic
(1) You can automatically apply geometric constraints but you cannot automatically apply a combination of geometric and dimensional constraints.
(2) You can manipulate dynamic block insertions but you cannot create dynamic block definitions.
(3) In the Autodesk® product suite, Recap is needed to import non-native point cloud formats and convert to AutoCAD's native rcs/rcp. For las/laz/pts/ptx, Map 3D and/or Civil 3D may be sufficient.
