BricsCAD versus AutoCAD® feature comparison.
| Drawings |
BricsCAD |
AutoCAD® |
| Lite |
Pro |
BIM |
Mechanical |
Ultimate |
LT |
Full |
| Native DWG file format (thru AutoCAD 2021) |
| Password Protection |
| eTransmit |
| Sheet Set Manager |
| Geographic Location |
| Drawing Compare |
| Cloud Collaboration |
| Interface |
BricsCAD |
AutoCAD® |
| Lite |
Pro |
BIM |
Mechanical |
Ultimate |
LT |
Full |
| Dark and Light Color Themes |
| Industry standard commands, aliases, and variables |
Command Line (Autocomplete, Midstring,
Clickable options)
| Start tab |
| File (Drawing) tabs |
| Model and Layout tabs |
| Layout Manager |
| Menu bar |
| Toolbars |
| Ribbon |
| Tool Palettes |
| Contextual Right-click Menus |
| Contextual Quad Menu |
| Status Bar |
| Workspaces |
| Searchable Settings (Variables) Dialog Box |
| Lockable Interface |
| Clean Screen Mode |
| Drawing Explorer |
| Customizable User Interface (CUI) |
| Structure Browser |
| Selection, snap &
track |
BricsCAD |
AutoCAD® |
| Lite |
Pro |
BIM |
Mechanical |
Ultimate |
LT |
Full |
| Selection Filtering (QSELECT) |
| Add Selected |
| Select Similar |
| Selection Cycling |
| Entity Snaps (Osnaps) |
| Polar Tracking |
| Zintersection 3D snap |
| Nearest Distance |
| Adaptive Gridsnap |
| Real-time boundary detection |
| 2D Dynamic UCS |
| 3D Dynamic UCS |
| Drawing tools |
BricsCAD |
AutoCAD® |
| Lite |
Pro |
BIM |
Mechanical |
Ultimate |
LT |
Full |
| Line, Polyline, 3D Polyline, Spline, Ray, Xline |
| Multiline and Multiline Styles |
| Circle, Arc, Ellipse, Elliptical Arc |
| Polygon, Rectangle, Region, Donut, Point |
| Helix |
| 2D Parameters, Constraints |
| 2D Autoconstrain |
1 |
1 |
| Annotation tools |
BricsCAD |
AutoCAD® |
| Lite |
Pro |
BIM |
Mechanical |
Ultimate |
LT |
Full |
| Dimensions, Dimension Styles |
| Multi-leaders, Multi-leader Styles |
| Single and Multi-line text, Text Styles, Text Editor |
| Hatches, Gradients, Hatch/Gradient Editor |
| Wipeouts |
| Revision Clouds |
| Attributes, Attribute Editor |
| Tables, Table Styles |
| Fields |
| Data Extraction |
| Data Linking |
| Annotation Scaling |
| Spell Check |
| AutoCAD Mechanical Compatibility: Read, Display, Edit (with
limitations) |
| Editing tools |
BricsCAD |
AutoCAD® |
| Lite |
Pro |
BIM |
Mechanical |
Ultimate |
LT |
Full |
| Move, Copy, Rotate, Scale, Stretch, Mirror, Align |
| Trim, Extend, Lengthen, Break, Join |
| Fillet, Chamfer |
| CopyGuided |
| MoveGuided |
| Grip Edit |
| Properties panel |
| Manipulator (3D Gizmo) |
| Draworder |
| Undo Per Entity (Property History) |
| Optimize |
| Simplify |
| Reference tools |
BricsCAD |
AutoCAD® |
| Lite |
Pro |
BIM |
Mechanical |
Ultimate |
LT |
Full |
| Blocks, Block Editor |
| Dynamic Blocks |
2 |
2 |
2 |
2 |
2 |
| Block Face Camera |
| Blockify |
| Associative Arrays |
| Dwg (Xref) Attach, Clip, Bind, Edit |
| PDF Attach, Clip |
| Image Attach, Clip, Adjust, Transparency |
| Point Clouds Colormap |
| Visualization tools |
BricsCAD |
AutoCAD® |
| Lite |
Pro |
BIM |
Mechanical |
Ultimate |
LT |
Full |
| Layers, Layer States |
| Transparency |
| Visual Styles |
| LookFrom (ViewCube™) |
| Match Perspective |
| Lights |
| Sun Properties |
| Materials |
| Render |
| Animation Editor |
| Walkthrough navigation |
| ANIPATH command |
| Modeling tools |
BricsCAD |
AutoCAD® |
| Lite |
Pro |
BIM |
Mechanical |
Ultimate |
LT |
Full |
| ACIS Modeling |
| Solid and Surface Modeling |
| Solid Primitives |
| Mesh Primitives |
| Polysolid |
| Union, Subtract, Intersect, Interfere |
| Extrude, Revolve, Loft, Sweep, Thicken |
| Twist |
| Fillet, Chamfer |
| Slice |
| Multi-slice |
| T Connect, L Connect, Connect with Nearest |
| Extract Edges |
| Direct modeling |
| Deformable (Freeform) Modeling |
| Audit, Simplify |
| Stitch |
| 3D Parameters, Constraints |
| 3D Autoparametrize |
| 3D Blockify and ParametricBlockify |
| 3D Parametric Design Tables |
| Section planes |
| Drawing Views: Base, Projected, Section, Detail and Break Views |
| 3D Threads |
| Point Cloud Align |
| Point Cloud Bubble Viewer |
| Civil tools |
BricsCAD |
AutoCAD® |
| Lite |
Pro |
BIM |
Mechanical |
Ultimate |
LT |
Full |
| TIN Surface Modeling |
| Civil Points |
| TIN Volume Surface |
| Grading |
| Alignments |
| Profiles (Vertical Alignments) |
| Corridors |
| Civil 3D Object Enabler |
| Boundary Trim |
| Building tools |
BricsCAD |
AutoCAD® |
| Lite |
Pro |
BIM |
Mechanical |
Ultimate |
LT |
Full |
| CAD-based BIM features |
| Structural Modeling Toolset |
| Project Database |
| Library Database |
| Site, Building and Stories |
| Windows and Doors |
| Fully Parametric BIM Component Creation |
| 3D Spaces |
| Quickdraw |
| Quickbuilding |
| Point Cloud Floor Detection |
| Point Cloud Projection |
| Point Cloud Geometry Detection |
| Point Cloud FitPlanar (geometry detection) |
| Propagate |
| Custom BIM Properties |
| Drawing Customizations |
| Analytical Model |
| Python Scripts (Beta) |
| Manufacturing tools |
BricsCAD |
AutoCAD® |
| Lite |
Pro |
BIM |
Mechanical |
Ultimate |
LT |
Full |
| Mechanical Browser |
| Parts Library |
| Piping |
| Assembly Modeling |
| Exploded Views |
| Kinematic Analysis |
| Bill of Materials |
| Balloons associated with BOM and Drawing Views |
| Sheet Metal Design |
| 3D Solids to Sheet Metal Parts Recognition and Conversion |
| Corner Relief for Adjacent Edge Flanges |
| Lofted Bends |
| Other features: Junctions, Miters, Tabs, Form Features |
| Coloring |
| Diagnostic & Repair for Invalid Sheet Metal Features |
| Batch Processing |
| Import, export,
output |
BricsCAD |
AutoCAD® |
| Lite |
Pro |
BIM |
Mechanical |
Ultimate |
LT |
Full |
| Print/Plot |
| Publish/Batch Plot |
| CTB & STB Table Files |
| PC3 Printer Configuration Files |
| Named Page Setups |
| PDF Import, Export |
| DAE Import, Export |
| IFC Import, Export |
| 3DM Import, Export |
| LandXML Import, Export |
| Import Civil 3D |
| RFA Import |
| SKP Import |
| DGN Import |
| RVT Import |
| DWF Export |
| SVG Export |
| FBX Export |
| STL Export |
| Point Cloud Export (see below the available formats) |
3 |
| las |
3 |
| pts |
3 |
| Point Cloud Import (see below the available formats) |
3 |
| las |
3 |
| laz |
3 |
| pts |
3 |
| ptx |
3 |
| e57 |
3 |
| rcs |
| rcp |
Additional formats available with BricsCAD Communicator (see below)
| CATIA V4 4.1.9 − 4.2.4 |
| CATIA V5 V5R8 − V5−6 R2021 |
| IGES up to 5.3 |
| Inventor V11 − V2022 |
| JT 8.x, 9.x, 10, 10.2, JT 10.3, and JT 10.5 |
| NX 1 − NX 195311 − NX 1953 |
| Parasolid 9.0.x − 33.0.x |
| Pro/E / Creo 16 − Creo 8.0 |
| Solid Edge V18 − SE 2021 |
| SolidWorks 2003 − 2021 |
| STEP AP203, AP214, AP242 |
| STL All (Graphical data only) |
| VDA−FS 1.0 − 2.0 |
| XCGM R2012 − 2021 1.0 |
| Programming |
BricsCAD |
AutoCAD® |
| Lite |
Pro |
BIM |
Mechanical |
Ultimate |
LT |
Full |
| ActiveX |
| Extended Entity Data Editor |
| Script Recorder |
| Full LISP Support (vl, vlr, vla and vlax) |
| Solutions Development System (SDS/ADS) |
| DCL engine |
| COM API |
| VBA Projects Support |
| .NET |
| BRX (ARX) |
| TX (Teigha eXtensions) |
| CUI menu files support, with Diesel expressions |
| Licensing |
BricsCAD |
AutoCAD® |
| Lite |
Pro |
BIM |
Mechanical |
Ultimate |
LT |
Full |
| Multi-platform Licenses |
| Perpetual |
| Perpetual + Maintenance |
| Subscription |
| Network Multi-user |
| Volume (Perpetual) |
| Academic |
(1) You can automatically apply geometric constraints but you cannot automatically
apply a combination of geometric and dimensional constraints.
(2) You can manipulate dynamic block insertions but you cannot create dynamic block
definitions.
(3) In the Autodesk® product suite, Recap is needed to import non-native point cloud
formats and convert to AutoCAD's native rcs/rcp. For las/laz/pts/ptx, Map 3D and/or Civil
3D may be sufficient.
